UPDATE- First off,I`m a Flathead,I never use tone controls or EQ`s,and my preamp is always in the by-pass setting. I started testing these with the Emotiva DC-1 as a preamp.While the Emotiva DC-1 is a great DAC in my opinion ,it has always fallen short as a preamp,on every amplifier I ever tried it on.
Why would I think any different now?Well I figured its short comings were because it is pro gear,and I wasn`t using in on pro gear,so it should work better on pro studio monitors,WRONG!!!
When I first listened to the m3-8`s with the DC-1,I could not sit close enough to the speakers to be in the near field due to the thump in the bass.This caused me to assume they are more of a mid-field than a near field speaker.Well that assumption was wrong,though I felt forced to back away from the speakers due to the bass.When I sat back about 8 ft,the bass was more tolerable,but there was hardly any top end.
I waited 2 days of break in to see if this changed,no change.
All I could think is that the DC-1 failed again to perform as a preamp,I was correct.
I hooked the DC-1 back up to my B&K MC-101 preamp,and ran balanced out to the monitors.
WOW- What a difference,I`m now able to listen in the near field comfortably.
These sound good in mid field,but you miss a lot of detail that was in the near field sound stage.Bottom line -do not buy them for any other purpose other than near field listening,If you want to fill a room,you may consider something more like the JBL EON`s..
I will include this in my full review next week,after full break in,and my stress test...peace
