looking to add components
Timmy245
Timmy245
hey josten
thanks for the advice & info
dw i believed you anyway :D but also thanks for the link and the pics : P
Timmy245
Timmy245
another problem sorry guys
my ps3 starts fine but after bout 10 minutes the fan is so loud and when you put your hand behind the back its pusching out so much warm air
it has been in the high 40s (celsius) where i live and unfortunately my room wont be aircondintioned for another week so is the heat causing this or is it full of dust just please dont tell me its stuffed and i would need a new one :(
please any help on this would be good
tim
Alex2507
Alex2507
Even though I'm no PS3 guru I will say that you're player is performing as intended. Where do you live, Australia? 40 degrees Celsius is really hot. I can't imagine that your player is old enough to need a 'dusting out' but any electronics with a fan needs that eventually IMO. I would get very good instructions on that before poking around in there.
Timmy245
Timmy245
thanks alex
btw it doesnt do it when im listening to music only when gaming
