Hello, I'm looking for front ported bookshelf speakers with DEEP bass extension, budget: 5000$ for amp+speakers
Any recommendations for bookshelf speakers that are front ported that:
-Are front ported or sealed or just don't have the port in the back
-Are fun and musical
-Have deep bass extension
Any recommendations?
Like a lot of people you want the moon and can't have it.
As I have posted many times, there is an inverse relationship between bass extension and sensitivity.
If you did try and design a bookshelf speaker to the spec you are asking for you would have a very insensitive speaker that would also have very poor output, as the driver would be severely excursion limited. It would also be compromised by dynamic thermal compression.
The best bookshelf speakers have a lower extension in the 50 to 65 Hz range.
So you need to change your design plan if you want anything worthwhile.
You need a much bigger speaker, or good bookshelves and a good sub or two.
Those are your only choices if you don't want severe disappointment.
