The Request:
I’m looking for model suggestions and first hand experiences as I sell my beloved JBL S310ii and select 3 bookshelves for my new LCR reference speakers in a large, open room. Music performance is my top priority as that’s where the vast majority of my critical listening is.
Things that matter to me:
Price: $500/speaker (current total $1500). I’ve got a long upgrade list, so I can’t blow the budget on one purchase. These will be the best speakers I’ve ever owned, but they don’t need to be the “exit system”. I’m willing to increase (maybe $2000), but it would need to be for real bang-for-the-buck, not incremental improvement.
Sound: I would like clean and accurate, even at loud volumes (don’t we all). I like a forward high-end, probably due to my time with my JBLs, but easily got used to the more linear SVS Ultras. I need even dispersion (linear off-axis), not only for the acoustic benefits espoused by Floyd Toole et al., but because I’m often hosting listening parties with many seated out of the sweet spot.
Support: Having replaced a tweeter and crossover in the JBLs, I’d like to have reasonable access to new replacement parts down the road.
Form factor: Bookshelf/monitor. I want to go with 3 identical front channels and don’t have an acoustically transparent screen. That being said…
Things that don’t matter to me:
Size: My last set of “bookshelves” were the JBL S38ii at 18x12x13”. I’m not afraid of big speakers, in fact, larger may be better from an engineering standpoint. I have 19” of height clearance below my screen on top of my rack.
Looks: I dig sexy speakers, but I’m lucky that my SO will cut me some slack in the aesthetics department. I probably wouldn’t rock a set covered in carpet, but I don’t need real wood veneer either.
Sensitivity: I currently have an Onkyo TX-SR706 rated at 100w into 2 channels, so I’m good for the time being with low-sensitivity speakers. On top of that, I have an AVR upgrade on the list, and wouldn’t be opposed to
a nice outboard amp from Emotiva at some point.
Low-end extension: Linear to 60-70hz is fine. I’ll be crossing over to one, perhaps two, SVS subs at 80hz, so any response lower than that is partially wasted.
The Candidates so far (links go to product pages):
- SVS Ultra Bookshelves: One of the few on the list that I’ve heard, and my benchmark. A great looking and sounding speaker and something I’d be happy with, but I’ve got to explore my options.
- Ascend Sierra-1: One of my top picks based on the internet-buzz around these, and they aren’t shy of measurements. Are the NRT Tweeters worth the extra $300/pair?
- Aperion Verus Grand Bookshelf: Highly regarded when they were released, but perhaps the luster has worn off a bit as some serious competition has been brought to market? Shameful that I haven’t heard them as they’re only 1.5 hours up the road, I loved the 4T, and the price is very right at $350 each (will they hold up with others at double the price?)
- Philharmonic Philharmonitor: A good pedigree and lots of buzz, but still the new kid on the block. Based on the manufacturer's measurements, the ribbon tweeter appears to hold off-axis response very well.
- Revel M105/M106: I couldn’t find a pair of JBL’s suitable to throw into the mix (I’m open to suggestions), so my HK pick has to come from Revel. A well-regarded brand.
- PSB Imagine B: I’d love a good deal on the Synchrony series, but the Imagine fits the budget. PSB is pretty universally loved, and I heard an older pair (Images?) from mid 2000 that sounded pretty good.
- Golden Ear Aon 2: Interesting design and lots of buzz around the low distortion of the tweeter. More extension than I need and I’m a little worried that more engineering was put into low-end extension than mid/high reproduction. Still, good reviews.
- Paradigm Studio 10: The Canadians and their anechoic chambers sure make good speakers, and the face looks like it was designed by Ironman. Rumor has it, there’s a place about 30 minutes away where I can listen to these.
I know, I know...I need to just bite the bullet and whittle this list down to 3-4 that I could realistically listen to, but it’s hard not to consider all the options. Let me know if I’m missing something.
If you’ve read this far, you’re really dedicated. Thanks. Let me know your thoughts as I look to make a major, to me, purchase.
