Looking For a 27" Monitor >$300
GranteedEV
GranteedEV
So which would be a better bet? The Qnix or the sammy?
IIRC Qnix uses samsung panels anyways. I like the Qnix because they have a rep on gaming forums for being pretty overclockable to over 96hz, many hitting that vaunted 120hz mark. The comparable Samsung monitor is $550. Yet another monitor which uses this same panel, and with a slightly different set of tradeoffs is the X-Star DP2710, but that's not sold by newegg (you can get it elsewhere though)
fuzz092888
fuzz092888
I'm thinking of going with the Sammy, just because the other two monitors only have the DVI-D right? I ain't got that.
BoredSysAdmin
BoredSysAdmin
which ports you do have ? Some adapters are really cheap and easy
like DP or MiniDP to DVI is trivial
BoredSysAdmin
BoredSysAdmin
like I said, mini-DP to DVI is a trivial adapter - the signal is the same.
http://www.monoprice.com/Product?c_id=102&cp_id=10246&cs_id=1024604&p_id=5999&seq=1&format=2
As for newer choices. I like the 27" samsung. 3x times the actual contrasts beats faster response time AND resolution.
That said, if 4k resolution is something you need, then by all means. Btw: For 4k Gaming at 30fps or higher in modern AAA titles you'd need one heck of a video card. think over $500 just in GPU(s)
http://www.anandtech.com/show/8662/best-video-cards-october-2014
