Logitech - Harmony Ultimate Home Remote $100
sholling
sholling
If memory serves this discontinued RF remote/hub combination was the predecessor to the $300 Harmony Elite and normally sells for $165-180.
https://www.bestbuy.com/site/logitech-harmony-ultimate-home-remote-black/8203175.p?
Includes:
  • Logitech Harmony Ultimate Home remote with rechargeable battery, Logitech Harmony Home hub
  • 2 IR mini blasters, charging station, USB cable, 2 AC adapters
From Best Buy:
Compatible with a variety of home entertainment and automation devices
Including Philips hue and Lutron Caseta Bridge lights, August smart lock, Nest learning thermostat and Honeywell Wi-Fi thermostat, PEQ and SmartThings sensors and more.
Remote
Allows you to control compatible home entertainment and home automation devices directly from the remote. A color touch screen, vibration feedback and motion-activated backlit buttons offer comprehensive, intuitive control.
Downloadable Harmony app
For iOS and Android lets you use your smartphone or tablet as a remote.
Hub
Relays commands from the remote for simple control, plus enables use with gaming consoles and devices behind closed cabinets.
Charging station
Makes it easy to recharge the remote's battery.
Works with Alexa and Google Home
Voice control your home and entertainment. Tell Alexa or Google Assistant to turn on Netflix, dim the lights, play music, check traffic, order food, adjust the thermostat, and much more.
Apple, the Apple logo and iTunes are trademarks of Apple Computer, Inc., registered in the U.S. and other countries. iPod is a trademark of Apple Computer, Inc.
On-screen gestures
Change channels, fast-forward and adjust volume with ease.
Works with Nest
So you can adjust the temperature on the Nest Thermostat from your Harmony Ultimate Home remote.
Also compatible with select Sonos, Samsung, LG, Sony, Apple® TV, Roku and IR and Bluetooth gaming consoles.
