Who is Lonnie? The reason I ask, is that a hum sounds like a ground loop problem, not a problem with the amplifier itself. Some products are more sensitive to these types of problems, but it's not really the amps fault. The first place to start looking for a ground loop problem is your cable or satilite box. Disconnect the coaxial cable running into it and see if the hum in your system goes away. Where the cable/sat is grounded might have a different voltage than what your equipment is running off of, and the hum is that difference in potential. The fix is a ground loop isolator between your incomming cable/sat and the cable/sat box. Now, you have to remove the coaxial to test it... just removing the power to the cable or sat box won't test if it's a ground loop problem - you must completely remove the box from the circuit (RCAs count as a connection!). If that's not it, explore other possibilities within your system by systematically testing each piece of equipment to see if it is the cause. If you can't determine another cause, it might very well be a problem with the amp. I doubt it though, based on your description of the problem.
Now, I'm not saying that's a good amp and that you shouldn't return it, I don't know anything about this Emotiva brand. To be honest though, it does raise a red flag that the majority of reviews they get is from Audioholics, which seems to have some brands the forum falls overly in love with. A few subwoofer brands come to mind. Just a word of caution, again, not saying the amp is a poor product (I've never heard it before).
