DrMorbius Junior Audioholic Apr 8, 2026 #21 I found my RP8000 series 2 is outstanding for soundstage, and basically NO distortion - zero in fact! I have them set up for cinema and couldn’t be happier!
lovinthehd Audioholic Jedi Apr 8, 2026 #22 DrMorbius said: I found my RP8000 series 2 is outstanding for soundstage, and basically NO distortion - zero in fact! I have them set up for cinema and couldn’t be happier! Click to expand... LOL definitely not zero distortion. Soundstage is questionable as to how you define that, too.
Kingnoob Audioholic Ninja Apr 8, 2026 #23 DrMorbius said: I found my RP8000 series 2 is outstanding for soundstage, and basically NO distortion - zero in fact! I have them set up for cinema and couldn’t be happier! Click to expand... They look great, I’m using Klipsch icon . And I don’t have the $$ for any type of upgrade unless stuff breaks right now . RP original series went low then back up in price . My tv stand is not deeep enough to fit the center , and not tall enough to put it under the tv .
Kingnoob Audioholic Ninja Apr 9, 2026 #24 lovinthehd said: LOL definitely not zero distortion. Soundstage is questionable as to how you define that, too. Click to expand... zero distortion doesn’t seem possible, what’s the average ? Don’t avrs and all amps have some distortion like a few percent , then speakers add more ?
E EBN Audioholic Apr 11, 2026 #25 Kingnoob said: zero distortion doesn’t seem possible, what’s the average ? Don’t avrs and all amps have some distortion like a few percent , then speakers add more ? Click to expand... Full data set is available which was done with Klippel NFS. There is also the video review in the link which explains the results more in depth. Klipsch RP-8000F II Floorstanding Speaker Review Klipsch RP-8000F II Review www.erinsaudiocorner.com
Kingnoob Audioholic Ninja Apr 11, 2026 #26 EBN said: Full data set is available which was done with Klippel NFS. There is also the video review in the link which explains the results more in depth. Klipsch RP-8000F II Floorstanding Speaker Review Klipsch RP-8000F II Review www.erinsaudiocorner.com Click to expand... Looks way better than my klipsch icon kf-26, but since I’d have to settle for the smaller model even if I had $$ to upgrade I’d have to settle for 6.5” version. Could be years til I can upgrade. I’d expect 3 way for $800 ea off sale . Last edited: Apr 11, 2026
