Ive owned most of the Klipsch Heratige line at one point or another,the 2 biggest things to running them sucessfully in a home enviroment are to have them in a large room & to corner them,these are not audiophile speakers that neeed to be pulled 3 ft away from the wall,without cornering them your bass response will suffer badly.
With that being said there are things you can do to get them to sound a bit less bright,the easiest & most sucessfull method ive used is to dampen the horn throats & im not talking about using anything expensive either.
Remove the horn's & place them on a peice of cardboard or newspaper,get a tube of 100% silicone caulking & a caulk gun,paint the entire horn throat with thick layer of silicone & allow it to dry for 24 hours then replace the horns,you will hear a difference in tweeter & midrange response after this alteration of the horns,if you do not like the new sound simply wait a few days & pull the silicone off the horns with your fingers,silicone lasts forever but it does not adhere very well to most surfaces,dried silicone is very easy to remove unless the surface was primed with a special primer beforehand so dont worry about creating a situation that is permanent.
