klipsch kf28 icons need help with wiring
jdig
I purchased speakers at best buy as a display open box item. Heard them and had to have them. However, where the speaker wires go I'm missing 3 bridge plates. They had them cross wired somehow because of missing bridge. I'm ordering them thru klipsch but in the meantime how would I hook them up just the pair of speakers to my receiver? Would appreciate any help
zieglj01
zieglj01
If you are talking about the gold jumper straps that connect black to black and red to red,
Then cut some speaker wire around the same size - strip them and connect black to black
and red to red > then go ahead and connect one set of speaker wires from your receiver to
each speaker - hooking up to the bottom terminal connectors will be fine.
markw
What Z said. When you do this, you won't even need those "official" Klipsch jumpers.
