Once again...from Craig
http://www.tweakcityaudio.com/forum/showthread.php?t=11
Elemental Designs A7-900 ($2200 ID/SI): 116 points (63-53)
Epik Conquest ($1599 ID): 112 points (60-52)
SVS PB13-Ultra ($1599 ID): 109 points (57-52)
Epik Castle ($999 ID): 109 points (59-50)
AV123 MFW-15 Duals: 109 points (56-53) (note, duals were tested as duals are offered as a package) **due to amp failure issues, this rating is under advisement. The purchaser may find him/her self needing a replacement amp. This is being done at no charge to the consumer, but it is something which should be noted by potential purchasers**
Creative Sounds Dual SDX-15 driver + Behringer EP-2500 Amp + Behringer DEQ2496 ($1630 ID): 105 points (57-48)
JL Audio Fathom 113 ($3500 BM): 103 points (53-50)
AV123 MFW-15 ($699 ID): 103 points (53-50) **due to amp failure issues, this rating is under advisement. The purchaser may find him/her self needing a replacement amp. This is being done at no charge to the consumer, but it is something which should be noted by potential purchasers**
Def Tech Trinity ($3000 BM): 102 points (54-48)
Velodyne DD-18 ($5000 BM): 100 points (50-50)
