speakerman39
speakerman39
Hopefully your tv doesn't change it to 2.0 for output, some do....
Yeah, never thought about that Chris. How would I find out? If it does 2.0 that is PCM right? I will go into the menu and check it out. If it does do 2.0 ONLY, then I guess I may need a box like that. Thanks for bringing that to my attention.
Cheers,
Phil
Might depend a bit on source, too. IIRC often multi-ch OTA sourced audio is passed along fine, but those via hdmi inputs maybe not. Manuals aren't always clear. Easy enough to find out, surely you have an optical cord hanging around?
speakerman39
speakerman39
Chris, my TV has a PCM and RAW option plus it says fixed or variable out. There is even different sound-fields to choose from such as Standard, Theater, and etc. I even can adjust for any lip sync issues. So, hopefully I am okay here. Will read up on it and go from there. Thanks!
Cheers,
Phil
