Is the Onkyo TX-RZ70 the Best AVR under $3000?
Isosevodes
Isosevodes
The reviews are stellar, whilst the comparisons are few. Thank you in advance!
Tankini
Tankini
Oh boy, your gonna upset a lot of Denon fanboys on AH. Lol. You like it? Buy it. As far as best? Subjectively?
Best at what? What reviews are you referring to?
mono-bloc
mono-bloc
Reviews only tell you what you want to hear.
When did you last read a review where they reported the item as rubbish.. It's never going to happen ,, Everythings five star, and wonderful
I think your safest bet is Yamaha, specifically this one Yamaha RX-A8A AVENTAGE
Onkyo may be OK, but they are just emerging after an ownership change. Denon/Marantz are in turmoil at the moment, I have had two bad experiences with them under Masimo ownership. You really only know if they are any good by how many develop problems and how warranty claims are handled.
Isosevodes
Isosevodes
Thank you for the input. I’ve read great things about the Yamaha A8A as well. Have a great day!
Teetertotter?
Teetertotter?
"Denon/Marantz are in turmoil at the moment"
[Can you explain??? Both are of the DM Group]
I have owned Denon AVR's since 1993 and no Issues. I currently have a working 2017 Denon, resting on the side. I get a new model every so often.
That is a long story that has been well covered here. Short version, their current owners Masimo have run the outfit into the ground and chalking up large losses. Recently, Harmon International, owned by Samsung, have purchased Sound United for less than 25% of what Masimo paid for the outfit. Now the Federal Trade commission have held up the sale and going to spend up to a year trying to decide if it constitutes a monopoly or not. Either way it is still a mess. I have had two Marantz AVPs have premature failure of late. This all tends to go hand in hand with a struggling entity.
Your pre-pros were built under Masimo ownership? They were newer than 2022? I thought you had much older ones....
I don’t think most people would include any Onkyo on any “Best” lists.
How does one qualify for best particularly?
Combination of several things including pride of ownership, measurements, build quality, history of reliability, features, customer support, research and development, etc.
Everybody has different priorities.
So may have no actual advantages audibly? Do any mass manufacturers really qualify? There's so little to go on for build quality, history, customer support, R&D, etc.
Well strictly one was and one was not. They were virtually identical. The 7705 was bought at the end of 2019, and went to the recycling center at the end of 2024. The 7706 was bought in December of 2024, but installed mid January 2025 and failed three months later. I returned it to my dealer for warranty repair three days ago.
I purchased a Marantz 8003, which I still have, in 2008, as it was the first AVP that had HDMI. It replaced my Rotel AVP which did not, bought in 2005. I sold that for good money on eBay.
I purchased two Marantz 7701s in 2012. One for our Eagan town home, so my wife had a good system as she was still working. The other replaced the 8003 in our lake home AV room, as the HDMI needed updating. The 8003 blew a voltage regulator almost immediately it went into service and was promptly fixed under warranty, and had no further issues. As far as I know it is still functional.
I really should not have bought that 7706, as it was so similar to the 7705. But the AV 10 had a huge price tag. Well it did not take long for me to realize my mistake. However my dealer was good to me. When the 7706 returns I will at least put it in the family room and make sure it is working correctly and then think about selling it.
For the record all these units have had house surge protection and been run from an APC. The surge protection for the 7706 was NEC 24 the whole time it was in use.
The 7701 while in our town home did not have surge protection at the panel and no APC. It is working fine in our great room system.
The trouble is that Sound United have been tossed around like a hot potato and also Onkyo. So it is small wonder that quality issues are showing up.
Gene gave a clean bill of health to the AV 10 say I thought that risk was reasonable.
The 7706 came out in 2020, that's what I was referring to as being before Masimo.
dlaloum
It is a high performing, great value, AVR.
It has been objectively and subjectively tested (on here at Audioholics)
Its nearest competitors in objective performance, cost substantially more... Street pricing and deep discounts may alter the relative value status (obviously) - but for those seeking flagship level performance, near state of the art... but short of the cost levels of Stormaudio, Trinnov and their peers, it (and its Integra / Pioneer brethren) seem like a very good option.
In feature terms there may be some constraints depending on your setup requirements eg:
two sub outputs
No wides
But if you don't expect your setup to go beyond 7.2.4 - this definitely should be on your shortlist.
EpsilonZer0
EpsilonZer0
The RZ70 is quite stable and the platform was really built off of the flagship models of 2012 and 2016. So although the company has changed ownership, the heart hasnt changed. When I finally got to see the RZ70 side by side with my PR-RZ5100 (2016) I was shocked of the similarities. If it aint broke dont fix it.
two sub outputs
No wides
I know they use the ES9026 Pro, that is not ref class but close enough in terms of specs, but do you remember which DSP IC (or ICs if more than 1) they use?
dlaloum
I was just looking around for the same information.... sadly Onkyo/Integra have not been quite as forthcoming about the guts of their gear as D&M have!
ban25
ban25
Cirrus Logic CS49844A-CQZ. There may be others, as there are other ICs on the board including those beneath heatsinks, but that DSP is clearly visible.
