is my reciever to old and will this set up be ok?
russelljw76
is this 2 old?, will it produce clean sound? its 10 years old, but I think im getting it for 30 bucks now.
agarwalro
agarwalro
$30 is a great deal, but, you need to finalize the speakers before a receiver can be shortlisted. At minimum, the receiver does not have HDMI and pre-outs. This reduces your connection options.
russelljw76
yup, but the hdmi is for video and audio together. I just need it for audio. I can can take digital rca cords from tv or xbox to the receiver fine , right? Is there any need for hdmi if im just running audio? and the guy wont go down to 30 he said 50, so im on my way to pick it up now. got to go way down the pass to garden of the gods. I hate leaving my mountains.
agarwalro
agarwalro
If you are running just audio to the receiver, you will be fine since it has enough RCA and digital inputs.
russelljw76
ok I need more input from u guys, I have the denon 1803 receiver and it is rated for 6 ohm, I have 4 ohm audioengines in front, and olded bose 3.1, 8 ohm speakers in rear.
Do I need a center channel speaker? if yes, what should I get and what to do about the ohm difference?
thanks,
thanks,
Don't worry about the ohm difference, and a center speaker is not obligatory.
russelljw76
so im not missing any music? can I put a center speaker with the ohm dif? or is center only made for movie/home theatre?
thanks
thanks
A center speaker is best with HT, not necessary for anything else except SACD. Even then with good left and rights, a phantom center works well.
In my opinion most center speakers are so bad, you are better off without them. Any rig I have heard at Best Buy the center has been a total distraction.
russelljw76
thank you very much. I will not get one. what should I set my receiver on , direct? or 5 channel or it also gives me a option for 6 channel. is it bad to run it on 5 or 6 channel without a center, or does it not matter at all? im siked I am ordering the PA 150 sub, cant wait to get it!
Now you have a sub I would play it most of the time in 2.1 stereo mode.
As I understand it you have left and right fronts, a sub and surrounds. When you set up your receiver, do your speaker set up and just select the speakers you have and say no to the speakers you do not have. Then do your set up and let the receiver select the appropriate speakers by source. In your set up I would suggest you always play 2 channel sources with left and right speakers and the sub only. Make all your speakers set to small and let Audyssey do the rest.
russelljw76
I don't know how to set for 2 channel, I don't have a manual. I will have to spend some time messing with it.
russelljw76
oh no, my denon does not have room correction.
russelljw76
russelljw76
man, someone called me a troll. i aint no troll. i just need a bits of advice for setting up my system on limited budget.
