Well, moderate means different things to different people, we generally discuss in spl (sound pressure levels) measured in dB pegged to a reference level. The distance between you and the speaker as well as the speaker's sensitivity come into play. Seems to me many Elac speakers are better described as 4 ohm (try and find an impedance plot vs frequency since it will vary all over the place across the spectrum of frequencies). Personally seems Elac gets a lot of good PR but seems not as many excited about their experiences as one might think from the PR push. There's lots of good alternatives out there....
Don't remember how well the 1713 would handle 4 ohm, altho many Denon avrs do okay with such, but the lower end avrs not so much. At moderate levels (to me that would mean a movie played back at say -30dB from reference), it may not matter, but as you ask for more volume that can change....and moderate to you may mean -20dB which requires 10x the power...
Try this
spl calculator to start to get an idea of how the relationship of power, sensitivity, distance and level can change things. Assume the sensitivity rating of your speakers is a bit over-rated is a good idea, maybe add 3dB to make it more realistic.
Oh, and welcome to the forum!
