Sounds like the Roku chirp/beep. What Roku do you have ?
check for roku updates, make sure your stick is updated.
Or try re-pairing your TV to your Roku.
there was an issue depending on the age of your roku of battery drain of the remote, which caused Roku TV USB connection and roku remote to fail and that caused the chirp/beep.
