As I understand it, a sealed or acoustic suspension sub has the advantage of using the pressure inside the cabinet to better control the motion of the driver.
This is true of a sealed box OR a ported box. Remember also that you don't necessarily want a box controlling the driver motion beyond a certain amount. If it's "pulling the driver back" after an excursion, that also means it was making it harder for the driver to make that excursion in the first place.
There's multiple factors - motor design, spider design, surround design, and box design - that should be weighed appropriately. Looking at one aspect alone is asking for trouble.
I know a ported sub can be tight, but I believe more money has to go into the driver to get there.
Actually, it's the sealed driver that normally needs more money, because it alone is responsible for output lower in frequency. Because of this, it has to be optimized for much longer excursions and have a very low resonance frequency. As a result, a small driver made to go low sealed, will have VERY low efficiency.
Hard to generalize I know, but I thought sealed goes lower, well because after the port tuning is hit the response falls off a cliff
By the time sealed officially goes lower, generally both systems will not be producing useful output, unless the room gives very generous pressure vessel gain.
As far as measurements shown in this thread, a few things I would warn against:
- look at the frequency response. if it's not the same, then obviously the waterfall and impulse response can't be the same. What if you shaped the knee of the ported design to match the sealed design or vice versa? Then you have the same frequency response but finally you can compare the differences (which will mostly be in headroom, as the sealed might have a bit more an octave below the vented's tuning, and the vented will have a lot more at and around its tuning. the other difference is physical size)
- those measurements are taken in isolation - IE a vacuum. They will simply be nothing like that for either system when placed into a room.
