Thanks for the feedback! I am definitely going to consider adding a second sub in the future! Maybe I'll grab another PB-2000Pro some time later and get them dialed in to get a great experience in all seats.
I have listened to the Klipsch The Fives Powered speakers and I was mighty impressed by them, have not heard any Focal but I do think there might be a dealer here in Vancouver where I might be able to demo them as you suggested. I guess I am worried about if an AVR alone will be able to power all 11 channels enough if I go with Focal or Paradigm (Klipsch should be no problem though I think). I see you are rocking some Paradigm and there is one other possibility I could go for in my theater since they are based in Canada:
Paradigm CI PRO series
- LCR - CI PRO P1-LCR (behind Seymour AT screen)
- Surrounds - CI PRO P65-IW
- Height - CI PRO P65-R
Sub - SVS PB-2000PRO
What do you think about that?
