In-ceiling sub(s) - need help!
GO-NAD!
GO-NAD!
OK, I've settled on an in-ceiling sub (or subs) for my 2.1 system. I've decided against infinite baffle, as I don't want to risk becoming a neighbourhood pest. So, enclosed is the way I want to go. I just wonder - for a stereo system, would it be better to go with 2 smaller (8"?) - one above each main speaker, or a single 12" centred between the mains? I would like good SQ, a flat FR (or flat as can be expected), good extension (for music, I think 28Hz is plenty deep) at high (but not deafening!) SPL.
I plan to incorporate a DCX into the system, for crossover and equalizing purposes. I think a 500 watt plate amp should do the trick for power. Any arguments? I've just downloaded WinISD Pro, but haven't had a look at it yet. I would probably rather have an experienced sub builder model it for me... That's a hint...
I was thinking that it would be a lot more work than a freestanding sub, but then I realized - I don't have to pretty it up! So, losing the finish work will probably even out with installing the sub(s). I know I'll have to do some plaster work, but that's muuuccch simpler.
I await some suggestions.... :)
adwilk
adwilk
Sounds like a fun project. I'd be more inclined to use stereo subs than a single one. Thats always a better solution for music IMO. It will also help from having localized bass at times. I'm excited to see this take shape.
GO-NAD!
GO-NAD!
I'm definitely leaning that way. I'm pretty sure that's the way I'll go, unless somebody gives me a good reason to go with a single larger sub. Two will certainly be more work, but I think it would be worth it.
GO-NAD!
GO-NAD!
By the way, if it will help with recommendations, my budget is in the C$500-$600 range for the drivers and amp. The DCX will cost me about C$400. I looked into ordering one from the US, but after exchange, duty, brokerage, etc., it would end up closer to $500. Besides, I could do without the potential warranty hassles. I've seen a BASH 500 for C$260 - that leaves a maximum of about $340 for drivers. Can I build a good pair of 8" stereo subs for that. I'm not including cables in the budget - they're dirt cheap at Monoprice.
