If 3db increases power by double.....
does it also increase volume by double?
That is the issue of having enough power to play wide dynamic material with wide dynamic range. A 1 db increase is just about what you can detect, some seem to need a 2 db increase. 3 db is the first step up the ladder easily detectable.
In listening to uncompressed sources the average power is low but peak power high. That is why you actually need higher power reserve from a lot of classical music ad opera, then you do for pop and rock music.
shadyJ
Speaker of the House
Staff member
'Loudness' is the perceived change in amplitude. 'Loudness' is a psychoacoustic metric so its not an absolute and so is subject to individual differences. There is some other oddities such that while many people perceive a 10 dB increase as a doubling of loudness, they perceive a 6 dB reduction as a halving of loudness. And this is all frequency dependent too. Increases in loudness changes its scale depending on frequency, so it depends on whether we are talking about bass, midranges, or upper treble. The don't react the same to human perception, even for the same corresponding changes in SPL. For my own perception, I would say that a 10 dB increase is quite a bit more than a doubling.
davidscott
davidscott
Agreed.
JerryLove
JerryLove
Putting a second speaker playing at the same volume would be +6db... so it would be the most literal "doubling" of loudness :)
On your avr with a dB volume scale pretty easy to tell for yourself what 3dB difference is...or 6 or 10....
