i was bored so i made this
craig7
the ultimate home theater, maybe
120" panasonic tv 18" subwoofers
3 htpc's
behind the seats, 5 18" subs
in the walls, 4 3 way speakers with 2 10" woofers, and a 2" tweeter
sony STR-DH700 7.1 receiver (very similar to the one i have), VCR, TIVO, Xbox 360 elite, ps3, blueray player.
buttkicker tactile transducers under every seat
9 subwoofers, 20 10" woofers, 10 2" tweeters, 3 1.5" tweeters, 6 8" woofers, 7 tactile transducers
took me 4 hours
lsiberian
lsiberian
Why in the world would you have a sony avr in there????:eek::eek: :D:D
Yeah I didn't even see that. You gotta have a pre-pro and a stack of pro-amps in there.
Not to mention no PJ?
You gotta have a PJ, vertical center behind an AT screen. I'd use those klipsch surround speakers for surrounds. Maybe the B&W 802d's for the fronts.
It includes a Sony receiver. Definitely NOT ultimate.
As mentioned, those subs are probably not going to work well the way they are setup.
craig7
i can download a pre made emotiva xpa-5, would that work?
edit: they look the same so ill just use the xpa 5 and put xpa 1 on it :p
craig7
You are going to need a bit more than one XPA-5. That might handle one side of the room; you have like 15 speakers in there :). For a home system, most likely don't need that many either. 7 would easily be plenty for an enclosed, treated room.
yea but this is about complete overkill, right now its 10.2, i want to do 22.2
I know, it is fun to play around with this stuff and props for the effort and taking it to the next level :D In reality though, I shoot for the simplest system that can get the job done well. Fewer components to do the job means fewer things to go wrong :)
craig7
soo true :cool:
craig7
Why 3 HTPC's? I'd go for one fully loaded mac pro :D
i was going to use one but i coldnt find a good model of one but i got one for it now, it is really mindblowing how awesome the mac pros can be
craig7
and since were doing overkill, im thinkin, 3 mac pros, 32gb ram each, 4tb hdd each. just them alone wopuld be about $90,000 because each of them would be about $28,000
craig7
my new additions
12 xpa-1's
2 subs in each corner
Two 2.93GHz 6-Core Intel Xeon “Westmere” (12 cores)
32GB (8x4GB)
2TB 7200-rpm Serial ATA 3Gb/s hard drive
Two ATI Radeon HD 5770 1GB
Two 18x SuperDrives
Davemcc
Davemcc
When you throw around terms like "Ultimate", I am thinking more along the lines of this:
http://stranger-worlds.blogspot.com/2010/09/most-expensive-home-theater-6-million.html
I think I'd go with this one but I would have to clean it and reorganize to suit my style.
