I need a router ...
Alex2507
Alex2507
And here I was thinking Alex was going to bring up a manly subject like "power tools". :(
It took me a while but I just figured out that this post is in response to the thread title. The reason it took so long is that I come to this good place for almost anything and everything except ... power tool advice. ;)
Just to clarify: there's nothing really manly about mortising out a fire rated door for a mortise lockset. It's just really dusty and probably unhealthy. On a comical note I will say that I effed up every bathroom door on an entire wing of a small hospital in Didsbury, Alta some 25 years ago using manly power tools. I had a 'jig'. :D
Strube,
Thanks for the help. I should be good to go.
strube
strube
Hmmm ... so is this the router of the year ???? :)
I just noticed this little goody. Confusion sets in ...
Nah, I just haven't upgraded to the one I recommended you because I don't use wireless that much, and mine has gigabit ports too, which is all I need ATM. Sorry to add to the confusion.
I still stick by my recommendation of the other one for you because it is cutting-edge, and I do have good experience with it, just not in my own networking cabinet. :D
Enjoy the movie. I hope she picked a good one. :)
jinjuku
jinjuku
Moderator
I have been using the NetGear WG614 series for years now. It's an inexpensive G router that does the trick.
Hit dealnews.com for router deals. I wouldn't have a problem with any Belkin/D-Link/Linksys/SMC. I have used them all.
I just recently put in two of the D-link N routers at a job site and was impressed with the feature set. But that could be a negative for the non computer types.
Post back when you get your router for some good tips on how to secure it properly.
Alex2507
Alex2507
I picked it up at Redbox after dinner and it was unbelievably bad. Something about Recognizing Your Saints. There's 1.5 hours of my life right down the toilet. :(
Will do. Thanks all. :)
GlocksRock
GlocksRock
I've used Linksys and D-link, and have been very happy with both. Not a fan of the netgear stuff though, it's not that good, and tends to get very hot.
Rickster71
Rickster71
It's funny you've mentioned that.
That's exactly what I thought at first, and that's the router I was going to suggest.:D
lsiberian
lsiberian
I recommend the Bosch 1617 :D I like it more than any other router I've owned.
As far as PC routers get Linksys they are owned by Cisco who basically are the networking company.
I've had D-Link's go out on me, but never a Linksys.
jinjuku
jinjuku
Moderator
Huh... I have used the crap out of netgear stuff and have it installed at both friends and customers for going on 8 years now... Been happy with their various products. Not saying I have used everything they ever produced.
GlocksRock
GlocksRock
Maybe their older stuff was good, but I've not been too impressed with the stuff that I have used. I guess it's a crap shoot... I'm sure all brands have their issues.
I've used Linksys & Netgear as well.
The Linksys is still working fine.
I've probably screwed something up with the Netgear router. It didn't work that well for me.:D
lsiberian
lsiberian
For H'ers you want to know how to reset your router and sometimes flash it.
Nemo128
Nemo128
Linksys WRT-350N + DD-WRT firmware is solid and secure. I use three, one as the DHCP server, two as repeater bridges over 3 stories.
The DLink 655 is another great one.
If you don't care about these so-called N speeds, pick up a Linky WRT54GL or 54G V1-V3, throw Tomato on it, get some 7-12dB antennas, and you're gold.
jinjuku
jinjuku
Moderator
For sight to sight bridges you can go cantenna... Where you getting your hi-gain omni's from?
abboudc
I second getting a router that is supported by DD-WRT or another open source firmware (like Sveasoft, though it's a bit sketchy).
Linksys's out of the box firmware stinks on just about all their routers.
I still have a V2 WRT54G flashed with DD-WRT acting as a bridge for my 360. With the linksys firmware i had to reset it about once a week. With DD-WRT I think i've reset it once.
You don't need an N to stream, a G will work fine if you can find one cheap.
lsiberian
lsiberian
Yeah the software sucked *** on my Linksys routers. I use to run the japanese version of their firmware. No I don't speak japanese either, but I knew where my settings textboxes were and the stuff worked correctly with PPPOE.
