I need a cd player. Which one?
ParleyW
HI,
i am currently in a market for a cd player, top of mid range would do it fo me probably. Is there a lot of difference in the sound quality in this area trough digital output? i would also prefer something compact design like the Denon or Teac players out there but not essential. if i am looking at the 2nd hand market what brands/models i should look for? and what year? is it worth getting a model from early 2000 or lets say stay in the past 10 years timeline?
Or maybe a dvd player? as i won't listen to cd-s with the tv on, but rarely playing a dvd might be an extra feature (twice a year probably :))
Thanks
Here’s a thought I’ve had with CD players. I’m a network engineer by profession. Having this in mind, the coax/fiber out from the CD player is just digital data. No sound, just data into your preamp. So every cd/dvd player will be equal sound wise. Now for longevity, I’ve had a Denon DVD 900 for twenty years. It just won’t die.
Mikado463
Mikado463
HI,
Thanks
So, it's been 2 months, did you get your CD player ?
miklek65
yes and no, but also yes :) i've got myself an x800 but i realized it is not the best as a cd player only. too circumstantial, no led screen showing which track played etc. It meant to be used with the tv what i don't want, and the streaming and other features also done by the tv and receiver, so i dont really need that kind of device. o i get rid of that and i pick up a sony cdp-xe510 in mint condition with remote and manual for a fraction of the price of the x800.
Mikado463
Mikado463
Bummer, should have got what I suggested (post #9)
K
Kleinst
I think this older post helped me a bit. I started listening to CDs again a bit and found with some the audio quality was much better than I would get out of Itunes. However that's not the case on all of them. Some seem to be recorded better than others but that's another point.
What I did today was A/B a bit the OPPO 83 DVD player I generally use (hooked up via HDMI) to my receiver vs a Sony UHD player.... As you would expect, didn't notice any improvement or difference. I assume that's because it's a digital transmission of the 1's and 0's that my receiver translates right? In that case, as has been mentioned, you could get a $5 DVD player from Goodwill that would do the same I'm guessing. So I guess I'm a bit less bullish on finding an improvement over the OPPO i'm currently using.
I guess it's more of a sharing than guidance or a question.
But I guess the question I'd ask is if you all disagree and when is there really a difference? Is it running analog via RCA into the receiver and going direct? Frankly I run Multi Channel Stereo so would that even work if you have to select direct? Sounds like a PIA frankly to change from what I have so only willing if it's a difference maker.
All have a good weekeend
HI,
Thanks
The late Ted Perry, founder of Hyperion records, use the say, "The ability of a CD player to play most discs is inversely proportional to its cost! I think he was right.
If it is only CDs you want to play, then the cheapest with an HDMI output is what you need.
If you want a universal player, then that is another matter.
Verdinut
Verdinut
mono-bloc
mono-bloc
There are CD players, and yes there are high-end players, But at the top of the line there is the Gryphon Ethos
Yes, but it will probably not play as many discs as the cheap CD player and will not sound the slightest bit better. This is fraudulent Audiophool nonsense.
K
Kleinst
I'm guessing the older OPPO i'm using is more than fine. I also have a Sony X800 I could move in there. I also have an Sony X700 and that is what I compared with the OPPO today. Anyways, the Sony didn't sond any better than the OPPO. Might have been worse but certainly wasn't much different.
I think it might be fun to look out for a higher end CD player used for a cheap price if it comes along but that exercise was very helpful for me today to realize that it's not likely going to make much difference frankly to you all's points.
TLS, what would a universal disc player be?
One that plays, CD, DVDs, SACDs and BDs. CD players just play CDs
mono-bloc
mono-bloc
Everyone has choice in what they spend there money on . high-end audio is no different to high priced sports cars or watches .
Some people simply like to indulge themselves, for no other reason. They simply can
Who cares what people with more money than sense do? High price sports cars often do have a performance difference, unlike watches. Just silly spending $65k on a cd player. $65K (even AUD) is silly.
Mark of Cenla
I mostly use DVD players to play CD's. They sound great to me. Peace and goodwill.
K
Kleinst
While we are thinking DVD/CD Players, Question, on my OPPO sometimes discs make an annoying spinning noise that I at least can't hear as much when the music is on. While other discs on the same player do not. Is this a problem with the player or the disc or perhaps both? Wondering if you have encountered this.
I need to try the same disc in another player but haven't done that yet.
Thanks
everettT
everettT
Thanks
If exposed to heat or humidity, say in a car, CDs can warp slightly and cause audible noises in a player. Hard to say if that's the case without trying the disc in another player.
Thanks
I think mainly the discs, as they are probably warped. CDs are not as long lasting as originally advertised. I can tell you that for sure.
