madmoly340
I just bought a Panosonic Home Theater system SC-PT760 i would like to know how to and what kind of DVD Disc to use i had another dvd player berfore this and everything i burned from windows media player worked fine on this i was useing dvd-r and i downloaded the movies from torrentz web site the mininova sight inside that web site now when i put these same disc in the panosonic it reads wrong disc can anyone help my email is madmoly340@gmail.com thanks
mike
Phil Taylor
Phil Taylor
Your home theater system's product description says it will play the following disc types --
DVD-Video, DVD-RAM/-RW/-R/-R(DL), +R/+R(DL)/+RW, CD, CD-R/-RW, Video CD, SVCD, WMA, MP3, JPEG
Looks like it covers about all the usual video disc suspects (except Blu-ray;)). Are you burning them as DVD media? It should play your -R discs... maybe it doesn't like the brand?
madmoly340
I am using windows media player and just hitting the burn button could it be the way it is downloaded from torrentz
Phil Taylor
Phil Taylor
Could be ... what file format are you are downloading? .avi or divx maybe? I use Nero for burning and convert files to DVD video first.
madmoly340
Help
Most are AVI or DIVX how do i convert them to DVD format
Phil Taylor
Phil Taylor
You'll need a program to convert those file types. I use Ulead VideoStudio SE DVD - it will convert .avi to DVD video - but it doesn't do Divx - try download.com and look around there - you may find a free utility... or you may have to buy one - regardless your DVD player won't play AVI or DIVX files and your discs will need to be in NTSC DVD video format.
madmoly340
help
thank you i will give it a shot
much help
mike
Phil Taylor
Phil Taylor
You're welcome - good luck ... converting video files can be a royal PITA and takes some time, patience... and a robust 'puter. ;)
