i got a great deal on Polk LSI M707 , need you advice
BoredSysAdmin
BoredSysAdmin
i have Yamaha RX-A2010 receiver
it's good enough or should i get different one?
can you recommend on AMP for one of those speakers:
Focal Electra 1027 - No need
Polk LSim 707 - Connect to avr first. If you feel you need even more volume get XPA-2
GoldenEar Technology TritonCinema Two Speaker System - No need
KEF XQ40 - No need
i bought those speaker cable:
Amazon.com: Dayton Audio SCP-6 Speaker Cable Pair w/Bananas 6 ft.: Electronics
good enough?
Yes
thanks
See my responses in bold
zieglj01
zieglj01
That is not a weak receiver - start with the receiver first.
Worry about any amps later - do not under estimate the
Yamaha.
pelo911
Yamaha.
i ask about the receiver because i have one more week to return it to the store and get my money back
and something else.
either to buy other receiver , or buy pre amp + amp
Josuah
and something else.
Where are you located? Can you try some neighbor's gear to do some comparisons, or get some other gear on a trial period within the week?
If your budget allows it, since you said you're more interested in music, I'd suggest trying out a few different DACs (instead of receivers) with the analog input of whatever you have available for volume control.
BoredSysAdmin
BoredSysAdmin
This is the dumbest idea I've heard in a long while - made my laugh actually
the Flagship is LSM 707
and for the price i can get this model , i think it's better to get it and not the Lsi 7/9/15/25
right?
there is no reviews for this model
maybe because it's new
Exactly my point, yes I know the LSMs are the current Polk Audio flagship, but they are not yet known quantities. The LSIs are known quantities, but they are 4 ohm speakers. Your 2010 will likely handle 4 ohm speakers well enough provided your room is not too big and you don't listen at high SPL.
It made me say "R----------------i--------------------g----------------------h--------------------t":D
Somebody needs to read The Audio Critic 101.:eek:
Amp, preamp, DAC, CD/BD player, wire/cable/cord are insignificant compared to loudspeaker, room acoustic, & processor.
Rebuttal: I don't care what all the "experts" say, I know what I hear. Yes, dammit, it's level matched.:eek:
pelo911
and something else.
djreef
djreef
Well, if you can get these things for half price....buy it.
....I don't even know why you would hesitate.
Seriously, even if you bought them and didn't like them, you could make money reselling them to someone else.
AND if you get cold feet, forward your deal over to me, and I'll pick those things up for that price in a heartbeat.
BTW: I'm running the full Lsi line in my HT and I'm perfectly happy with them. I would see no reason why the new speakers wouldn't be worth their price tag, and an absolute steal at half-price....
Ditto. Ive been running LSis on my HT rig for nearly a decade.
DJ
djreef
djreef
Separates almost always work better, but it should work just fine.
DJ
