I am sure this has been asked before a thousand times, but I am having a hard time pinpointing a post with similar stats.
In my theater I wired the speaker wires to come out of the walls at 5' except for the center and the sub. Center is at 3' and the sub is at front left. I have some flexibility from there, but that is where they are pre-wired.
Lets assume I am using today's speakers since I am highly considering buying these:
SX-661/R mains ($2,700/pair), SX-661C/R center ($1,350/each), SX-44/R side surrounds ($2,500/pair), and SX-61/R rear surrounds ($1,900/pair); Total: $8,450
My questions are:
1) Having the center at 3' and the fronts at 5' would this cause major issues in the front sound stage?
2) If I were to put a AT screen in instead I would have to mount it off the wall far enough to get these behind it. Then I could get all my speakers at 5' and I assume I would drop the SX-661C/R for another standard SX-661/R. How would you mount a fixed screen off the wall? Would you use a drop screen instead? and How far does the screen need to be from the front of the speakers (3-6 inches enough)?
3) With a good system like this will it make a huge difference? My preference is to use a fixed screen on the wall and put the speakers around the screen since the alternative is much more difficult to install. I am looking for high quality though so I am willing to do whatever is best.
4) If you do put bookshelf speakers behind a screen would you put dampening panels between them? p=panel s=speaker and ---=screen
Something like this:
p s p s p s p
All of this is referring to my front stage only. The rest of the room I am fine with. I just need to make a final decision on my front stage. Thanks All!!!
