I also have a lot of experience with the PB16-Ultra.
Here is a review with extensive measurements. It is a very good sub, but its performance wheelhouse is more in the 16 Hz to 40 Hz range. That is mostly beneath the frequency bands of regular music. Above that range it is not bad, but isn't that much better than the ULS-15 or SB-13. Another potential issue with it is that it is very heavy- 176 lbs. You need at least two adults to carry it, and they have to be in good shape, seriously. What makes it worse is that its finish is a pristine gloss black, so you want to carry it in such a way that does not scuff that fine finish, and this is not an easy task, since it is quite large. By contrast the ULS-15 is only 65 lbs or so and is easy to move around by one person.
The PB16-Ultra will unquestionably give you superior performance for movies. It digs very deep and does so very cleanly. It has excellent non-linear distortion metrics, a tad better than the ULS-15 in the musical range of 40 Hz and above (although they are both so low in distortion that neither would really be audible). I would say that if you have the room for it, and money is not an object, and you will have a lot of help getting it into place, and you won't be moving it around after getting it into place, sure, go for the PB16-Ultra. However, for the same price as the PB16-ultra you could get three ULS-15s and that would be far superior in the music range of 40 Hz and above. You also do not need to be a power lifter to get them in place.
