Din61
What do you mean the drivers hit 400w at most?
No, I mean the power handling, those 3 IINFINITYs are rated rms @ 400/300/350w respectively, if choose one of them to build SEALED, how many do you think I'd need (in a 4000 cubes room at about 8ft distance)...?
Trying to think of who here built four for his room, think it was similar size....my room is fairly small (1400 cuft I think).
Din61
BTW, what's your opinion about QWR like TL/TH (over HR like ported), read a lot about them, efficiency and response seem to be much higher in comparison...? :rolleyes:
William Lemmerhirt
William Lemmerhirt
A lot more than if you built ported ones!
William Lemmerhirt
William Lemmerhirt
Obviously! That's why I'm now looking for some (justifiable) alternatives...
I see that. I couldn’t resist jabbing you a little bit since you’re stuck on sealed. Lol
Can you spell each of those abbreviations out?
Din61
(BTW = By The Way ;))
QWR = Quarter Wavelength Resonator
TL/TH = Transmission Line / Tapped Horn
HR = Helmholtz Resonator
Now read... :D
Now read... :D
Was QWR that I was most unsure about, but no, know nothing about quarter wavelength resonators, while familiar with the terms transmission line and tapped horn haven't dived into those much let alone tried to design/build one, altho some of the transmission line designs might be interesting. Helmholtz resonators you're talking ported subs? Or an absorber? If you have the building/design skills for the more complicated designs go for it....
Din61
Well, QWR in the most understandable form is an enclosure itself acts as a resonator (taking the shape of a tube where 1/3 of its length becomes the vent while the rest 2/3 being the chamber), HR on the other hand is simply a port inside of a chamber behaves just as you blow through a bottle tip (old-school science days :D).
So now thinking about a QWR as both its efficiency and response is seem to be higher than HR in most cases (since SEALED won't fulfil my room) and most importantly its group-delay is said to be lower (the reason I'm still worried about PORTED).
Update:
I know the theory but no modelling skills... :p
Din61
Hey guys!
I came up with something I'd call "innovative" (I don't know :rolleyes:)...
Just thought of some way to gain higher SPL out of a SEALED enclosure than by itself, check this out.
Note:
This is a direct-radiating horn for corner placement in the room.
