How much tweeter do I need with a 200 watt 12 inch pa speaker?
Aaron Bilger
Aaron Bilger
Sure. Why not? It's not like you'll be feeding it the same power as the woofer, assuming you've got a proper crossover, and that subject has already been covered.
Would you say that is the proper wattage on the tweeter and what would you say is a good crossover if you can give me a link to buy it from.
markw
Truthfully, it is.
I have no idea where you could buy one. That's TLS Guy's territory and he's already weighed in on this.
Seriously, kid. You're in way over your head if you want any sort of decent sound. ...and that's what we've been trying to tell you.
Aaron Bilger
Aaron Bilger
Truthfully, it is.
What do you think of this plate amplifier would Still need to buy or use a crossover with this? It has LF and HF one for the big woofer and one for the tweeter.
http://www.seismicaudiospeakers.com/150-watt-bi-amp-plate-amplifier-for-loudspeaker-cabinets/p/SA-APSC08
everettT
everettT
Parts-express.com
As TLS mentioned you need to model the woofer and then design a crossover. If you go with an electronic crossover you need an expensive plate amp with the features needed. You can go to http://www.eminence.com/ and research and partsexpress has some crossovers for their drivers, but IMHO just buy a finished speaker until you read up on speaker design.
Aaron Bilger
Aaron Bilger
Parts-express.com
Ok what about this crossover will it work?
