Home audio, Whats better than naim muso 2 i want to upgrade it? i want reference sound
the reason they use class d and crappy class d is,
they are cheap,
they doesnt care about quality, they try to save as much money as possible.... class d is energy efficient, and small size and cheap.
When they use even cheaper class d its even cheaper for them. Compared to using some branded class d ..amp.
A lot of them are very expensive and very good. There is junk, quality and everything in between in all classes, except straight B and C which are all junk pretty much.
I'm not sure that's accurate. Most active speakers use class D, but to my knowledge relatively few use Hypex, and Purifi is so new that I think very few if any active speakers use those modules (I don't know about any).
I think B & O use Hypex or did.
Sigberg Audio
Sigberg Audio
they are cheap,
I would assume most manufacturers are cost conscious, yes. As most other amplifier classes, you will find Class D amps ranging from poor, to among the best in the world.
