Hi Not sure if you are aware
but Naim is extremely high end brand - they install premium music in Bentley,
and people are crazy for Naim, i already have several offers for the muso 2 , so its an easy sale.
To summarize it naim uses 6 speakers which are small class d amp 75w each...
according to naim it have mid/low/high////
https://www.dxomark.com/speakers/Naim/Mu-so-2nd-Generation here is more info on naim specs.
Naim also have wired connection everything you may need, usb, aux, hdmi, optical connector everything, wifi blue tooth..
Naim doesnt use wisa protocol- which is CRAP.
For wisa protocol you need to have dedicated additional unit, which consumes more space/ more heat/ and more power thats not wireless thats tons of cables and gear, naim have only 1 power cable and thats all......
you can connect all phones,all laptops,all computers everything wireless or with cables... its up to user.
I dont care about dolby atmost - or spatial audio, which is gimmick, i will use speakers to play stereo music only.
As i mentioned in the past speakers will be imported either from USA/Canada or Europe ,we dont have market or brick and mortar or anything for high end audio...
I am considering wired system as well...
i am considering 3 way bookshelves speakers and + 1 amp.
