HK AVR 635 fan noise?
jetz9335
I just bought a brand new Harman Kardon AVR-635 system from a local store called Video Only.
A problem is that even after with all my effort this unit always runs fan and it makes quite noticible noise all the time. I tried lowering volume down to -35db, but still the system makes fan noise.
I understand that the system should need fan to cool down the unit when needed, but with this steep price I don't really expect this kind of noise level all the time by the fan.
I checked Harman Kardon's web site, and found that the fan actually shouldn't operate under normal usage. I'm not sure what they are referring by normal usage, but I suspect -35 db output would fall into normal usage.
Is my system defected? Any body has experience with fan noise?
-Sunghwa
Buckeyefan 1
Buckeyefan 1
Welcome to the forum.
That doesn't sound right. I would exchange the unit for a new one if possible.
jetz9335
Yes, it was defected one.
I got new system although it is display one. The new one absolutely doesn't run fan. At least I've never heard of any fan noise so far.
Somehow the store - "Video Only" is telling me that they've ordered new system for me, but it is delayed and it's been a week. They offered me temporary solution until I get the new one. So I got the display model which works just great.
Buckeyefan 1
Buckeyefan 1
That's great customer service. I'd make sure to thank them, and the owner. That goes a long way in repeat business, as well as referrals.
WndrBr3d
WndrBr3d
It was probably a faulty bearing on the HSF cooling the video processing unit.
I have an AVR7300 and then fan noise isn’t even noticeable when it's in my AV cabinet, so I doubt the 635 should be any different.
Best of luck with the new unit!
