Buckeyefan 1 said:
Taken from "Secrets"
Damping Factor
I can draw your attention to this part of the article:
Secondly, the effects of this loss of damping on system frequency response is non-existent in most cases, and minimal in all but the worst case scenario. Using the criteria that 0.1 dB is the smallest audible peak, the data in the table suggests that any damping factor over 10 is going to result in inaudible differences between that and one equal to infinity. It's highly doubtful that a response peak of 1/3 dB is going to be identifiable reliably, thus extending the limit another factor of two lower to a damping factor of 5.
This is what would be audible, level changes, but in the low driver this .1dB which is not the criteria for audibility just level matching components when comparing, is not even close to the low frequency JND threshold.
Much is made of DF, not much meat behind them.
REFERENCES
(1) James Kraft, reply to "Amplifier Damping Factor, Another
Useless Spec," rec.audio.high-end article
2rcccn$...@introl.introl.com, 24 May 1994.
(2) A. Neville Thiele, "Loudspeakers in Vented Boxes," Proc. IRE
Australia, 1961 Aug., reprinted J. Audio Eng. Soc., 1971 May
and June.
(3) Richard H. Small, "Closed-Box Loudspeaker Systems," J. Audio
Eng. Soc., Part I: "Analysis," 1972 Dec, Part II, "Synthesis,"
1973 Jan/Feb.
