HughB
I have an older version of a Statement D2. Over the past month or so when I power it on, the logo (Anthem Statement D2) shows up across the top but nothing else turns on. Cycling ON/OFF a few times worked - until yesterday.
The unit has power and turns on, however after it turns on and reads "Anthem Statement D2" nothing else seems to engage; no other indicators lights are illuminated as you can see from the attached picture. Any ideas on how to remedy this?
Did you try unplugging it (soft reset) or perhaps a full reset if it has one?
HughB
Hi.
Thank you.
Yes, I unplugged it for about 10 minutes but it didn't help. Did the same with the power switch on the back - still no help.
Hi.
Thank you.
Try leaving it off for about 1/2 hour- these can take some time to recover if a surge hits them.
