setting speakers to small
Set them to small, see if this helps. Someone could give a more detailed explanation on this but setting your speakers to small has nothing to do with the size of the speakers themselves.
Setting the speakers to "samll" really doesn't mena they are small. Typically whe you set to small at some crossover point ( usually around 80hz-150hz) the lower frequencies are sent to sub-out or LFE.
If you set to small and can adjust the crossover you can try various frequencies to obtain the sound you desire.
Many auto-callibration systems will set the subwoofer level very low.
A couple of things to check.
(1) In some cases it is front speaker size "small" or "large"; "small usually ensures bass output goes to sub.
(2) Sometimes the is a bass setting "main", "sub", "mixed"; needs to be "mixed" or "sub" ( many times the speakers size setting of "small" has the same effect.
(3) Most subs have a separate amplifier and hence a separate gain volume control; you probably will need to adjust this. I wouldn't suggest maximum at first, maybe somewhere around midpoint or lower and slowly increase. However, for some reason some subs have to have the gain set pretty high before they provide good "thumping" sound
(4) Go to your speaker setup menu and ensure that it says subwoofer="yes" and then look at the subwoofer dB level. As I said before, most quick-setup, auto-setup, or auto-equalization systems
set the level very low. Again, in use increments and slowly increase the Sub gain.
Good luck and by the way very nice sub!
