C ConsoleChairman Enthusiast Dec 29, 2017 12 0 1 38 Dec 29, 2017 #21 30 day, I'm generally fine with buying used stuff
lovinthehd Audioholic Jedi Sep 11, 2012 44,870 0 113 Oakridge, OR Dec 29, 2017 #22 ConsoleChairman said: 30 day, I'm generally fine with buying used stuff Click to expand... My experience, and my brother's, with similar Pioneer avrs makes me omit them from consideration altogether, even new let alone used (both of ours failed in just a bit more than 2 years use). The QSC amp should yield any issues in your 30 day period and is less risk down the road IMO.
KEW Audioholic Overlord Jul 12, 2009 11,572 0 113 Jowjah Jan 2, 2018 #24 ConsoleChairman said: It was fine? I don't think I damaged anything if that's what you mean. At ~25/40 it's loud enough-ish, but the bass isn't strong enough and I don't know how much I could turn up the bass at that level without being too much for the receiver. Click to expand... So it sounds like you want the extra volume to achieve the proper balance of bass. For that reason, I would suggest you look for a used Yamaha and make certain it has their loudness knob. Lots of older units had loudness buttons, but they are a crap shoot as they were often over-blown, which is as bad as not enough. The knob lets you tune it.
C ConsoleChairman Enthusiast Dec 29, 2017 12 0 1 38 Jan 2, 2018 #25 I can't find the specific model right now, but there's a slim Marantz that can be had for ~$350 refurbished that has 2.1 preout, which of the two would be better? I think it was an nr1506 or 1605 or something like that.
