Help needed with In wall speakers
AlfieArch
I forgot to add 'uninformed' to the list. I worked on a project and when I mentioned network cabling, the carpenter said "But, I thought everything is wireless". I then had to explain that not only is everything not wireless, trying to do that causes a lot of problems.
Eppie
Eppie
Thanks! I was not aware of that feature! I’ll check those out!
Yes, the Triad speakers are good too. Built in the U.S. if you want to support local. They have higher end lines too depending on your budget. They work through a dealer network but DigitalDawn can help you with that.
