“IMHO, running that speaker configuration is just a really bad idea.”
Agreed. Just to help clarify loads that an amp could see, I’ve read reports where good quality speakers rated at 8 ohms will drop as low as 3.6 ohms at certain frequencies. In your configuration, this works out to 1.2 ohms. This type of load will put a tremendous strain, albeit momentary, on the amp. Also, there’s a chance that you’d lose a good portion of your dynamic range simply because the power supply will have trouble keeping up at higher volumes. High loads also increase distortion levels, and distortion is what does the most damage to speakers. In my own opinion, I’d have to think that an average steady diet of 2.67 ohms is just too taxing on an amp, even for those rated down to 2 ohms. It has got to shorten its’ life. I too would recommend using a different wiring configuration. It’s safer, better sounding, will add longevity to your equipment, and will open up your choices in amp selection (less $).
