Will Brink Audioholic Jul 4, 2020 135 0 16 44 Oct 23, 2023 #1 My Velodyne HGS 12 had died. It did it once a decade ago, I sent the plate amp off to be fixed, been good ever since. Seems to have died again. I love that sub. It was $ for the time, and is used for music only. I can send send off again ( I used ebcelectronics) or get a new sub. Fixing it is more cost effective, but I wanted to see what's out there in compact subs around 2k price range. Back in the day when I got the sub there was not than many brands, now it's endless. Maybe best to get two smaller subs? Medium sized room and music only using Anthem STR integrated amp and ATC SCM 19vs mains. Thanx
Bobby Bass Audioholic General May 20, 2023 1,491 0 36 Oct 23, 2023 #2 You’ve got a lot of great choices available. Arendal, REL and SVS to name a few. I went with a pair of subs for my music only 2.2 system. Are you looking to spend $2K each or for the pair? Reactions: Will Brink
BoredSysAdmin Audioholic Slumlord Aug 21, 2007 15,619 0 113 New Joisey Oct 23, 2023 #3 If you're not picky about looks (though the Rosenut finish looks nice to me) and don't need fancy electronic features, beating HSU on price/performance would be nearly impossible. ULS-15 MK2 Subwoofer :: Affordable Sealed Subwoofer Introducing the ULS-15 MK2 subwoofer, the renowned musical 15" subwoofer that has garnered immense popularity because of it's sealed subwoofer technology. The best, affordable sealed subwoofer HSU Research. hsuresearch.com get a pair of them while you are at it to even out room modes. As for compact, HSU is not too big at an 18" cube. Reactions: Steve81, Will Brink, Danzilla31 and 2 others
S shadyJ Speaker of the House Staff member Oct 16, 2006 12,053 0 113 Oct 23, 2023 #4 Definitely go for two subs. ARC room correction will do a lot better with two subs vs one. Dual Hsu ULS-15 mk2 is a great choice. Other good choices are a couple of SVS SB-2000 Pros or Arendal 1961 1S subs. Starke Sound SW15 is worth considering. If you aren't concerned about saving space, look at dual Hsu VTF-3 mk5s, dual Arendal 1961 1Vs, or dual Monoprice 12" THX Ultras. Reactions: lovinthehd and Will Brink
Will Brink Audioholic Jul 4, 2020 135 0 16 44 Oct 24, 2023 #5 Matt34 said: Two SB 3000 or JL Audio D110's for a music focused system would be awesome. Click to expand... Tight fit with two, but I know both brands well liked. The Velodyne is a compact 12" sub.
