Thanks a ton, I know most of you on here are advanced so I hope you don't mind a rookie asking questions. So knowing that I can't run the 901's and EQ thru my SC-07, would adding an Adcom GFA-2535 pre-amp add anything to the equation? I have a friend that said he would give me the GFA-2535 if it would work. I think I still have the tape monitor problem but I figured I would ask. Thanks again.
ps. While I am at it, I do have an older Yamaha reciever that does have a tape monitor but it is only like 60w. I really would love to keep using the sc-07 as my primary amp but if there is just no place for it with the 901 in any scenario it doesn't matter. Choices.
