He is correct..
I have it hooked up to the Sub Out. The Subs Xover is turned off, the Volume level is set on about "4", 0' phase.
It just seems unnatural to set my towers to small... But I think I understand why, they only go down to 60Hz.
It sounds like I did everything correctly, Ill switch my speaker settings to small, and set the sub freq to 120Hz.
I watched Toy Story 3 last night, It sounded really great with the settings i have now (speakers set to large) except during explosions and other "bass intensive" parts, I could hear the towers working to hard... I am guessing wan i switch them to small it will fix that...
Thanks guys
Your mains are actually very THX style.
They are about -3db at 80hz and about -6db at 60hz. This is a 12db/octave rolloff towards 40hz.
Now a THX crossover, with mains set as small, works like this
There is a digital 12db/octave high pass filter rolling off your mains, and a 24db/octave low pass filter rolling off your sub. The sub will be 6db down and the mains will be 3db down.
In other words, factoring in that your mains are already 3db down, there should be proper acoustical summing with your mains 6db down at 80hz and your sub 6db down at 80hz for flat frequency response.
Now other factors do exist...
1) Does your receiver use THX slopes in its crossover?
2) Is your sub otherwise flat up past 100hz?
3) Is the room creating problems?
