HELP!! B&W CM series vs. Paradigm Studio 60
sydney
Not to put you at odds with your SO, but why is real wood so important?? Personally, I find the use of a laminate veneer in an affordable speaker to be preferable if this allow the mfg. to then use higher quality drivers and cross-over components (or, put simply, if it sounds better).
For example, I find the laminates used on Paradigm Studio series speakers to be of very high quality - and they're likely to be more durable than the the paper thin "real veneer" that is found on most affordable wood covered speakers.
G
gus6464
If you go with the CM7 make sure you have a good amp to go with them. They can be power hungry.
TheFactor
TheFactor
I agree 100% , that is so true and some very good points.
trnqk7
The CM series is nice-I think it's where the B&W line picks up and becomes worthy of the name.
I would second the Salks-or at least researching them and seeing if anyone nearby owns them so you can demo them at home. I came pretty close to trying them but was a little scared. I love my speakers, but still wish I would have tried the songtowers-at least heard them. A TL speaker intrigues me since several of our well respected members trumpet their values fairly often.
