Hearing Protection and Listening Safety
In my case, there was no wanting to be a tough guy, but I ended up that way whether I wanted to or not. You must be significantly younger, or have lived in safer places. I can assure you that when I was coming up in the trades, OSHA was nowhere to be found. I started out at age 15, digging footers and pouring concrete in the FL sun without any SPF, either. After that I did hot tar and shingled/tile roofing with no UV protection, nor safety lines. Miles of rockwool sound blankets without dust masks in hospital construction, either. We hung inch thick gypsum core board on a 4 level bridge connecting two hospital buildings together, 70ft in the air using 2 x 10s and 12s for scaffold planks all of which we had to rig ourselves. I won't even get into all of the asbestos I scraped from red iron on commercial remodels. Not one workers comp claim in nearly 50 years in construction and I'm still in it full time.
Smoked Lucky's and Marlboros for 35 years, and was up to 3 packs/day when I finally quit at age 50. It's nice to see now that people wear plastic gloves to chop an onion or even loosen a lug nut but none of that was even available back then, when we could also chain smoke those Marlboros on a commercial flight to any destination.
I survived the immediately dangerous stuff and most of the long term stuff as well. Meanwhile, we have people using their health insurances as licenses to really bad health choices. I had one fellow on a forum who is nearly 400#, say that my health insurance should drop me for refusing the jab. Meanwhile he's got as bad a case of diabetes as a person can have, a bypass surgery, and a host of other weight related problems and a pharmacy's inventory worth of meds he takes daily. Me, I'm still hovering around my ideal BMI, with a healthy back, knees and hips, in spite of 20 years hanging and finishing drywall.
My hearing? I can't hear anything past 12khz, but music still sounds good to me so I guess I got lucky there. I do think about it though when things are getting loud. I wear my safety glasses when I should, most of the time. I have more visible scars on me than I would like, but at least it shows where I have been, a lot more than those tattoos the safe and soft people cover themselves with, these days.
I turn 68 in April and worked in a lumber yard after high school, so I was 18- we were required to wear hearing and eye protection because of OSHA. ALL of this stuff has been required for longer than I have been working.
My dad used to give me a hard time about my use of headphones and I eventually found that he was right after a couple of stupidly loud shows. My ears were screwed up for days afterward and I have carried ear lugs for more than 40 years.
I dislocated my left kneecap in 2021 and since there was nobody around to help, I slapped it back into place before getting up to try walking again.
Rub some dirt in it! :)
If they still work there and the company doesn't post notices about SPL or provide hearing/eye protection, someone needs to contact OSHA.
Better do it quickly before OSHA goes away.
mtbdudex
mtbdudex
A related article we just published so I added to this thread regarding noise in the workplace and how it affects productivity and mental health:
Gene;
I read your article, then clicked on the link to calculate desired SPL, and got this dead end.
mtbdudex
mtbdudex
I read that article, the link circled below was at the bottom of it, then clicked, and read that article, “Relationship Between Watts and dBs”.
The broken link is in that article.
Can you check it, does it work for you?
TIA
Mike Rosinski
Mark of Cenla
I play drums, and I always use hearing protection when I play or see live music. Peace and goodwill.
