nm2285 said:
Chris:
Thanks for the detailed post. My listening preferences are classic rock, jazz, blues (probably in that order). So I'd certainly like a headphone that performs well with all of them.
Well, the AKG K501 might be a contendor, in this case. The AKG K501(modified) basicly sounds very good on high quality recordings. On poor quality recordings(most modern pop, modern pop rock, etc. releases) it sounds terrible/annoying. For most modern pop/electronic music, I use a modified(I don't like it stock) Sony MDR-CD3000 headphone. Not a nuetral headphone by any means, but it's distinct coloration(s) make many modern pop/electronic releases sound very good.
Like I said, I'm not a huge fan of the Grado sound (too forward/dynamic for my tastes) and I prefer but am not in love with the Sennheiser sound. Do you have any other recommendations?
I feel exactly the same way about Grado(but have you heard the PS1? It's not forward like many of the other Grados--thought it's still not something I like due to it's very heavy bass balance). I also don't like Sennheiser particularly, at least in reference to the Sennheiser HD580, HD600 and HD650.
What is it that you don't like about the DT880s.
They sounded like they had basicly an even tonal balance, but they sounded too harsh, compared to the best headphones I have used. Something was off in the midrange. But realize that my standards are distorted, and might be considered unreasonable: I have a low tolerance for sound signatures that differ even slightly from my preference(s).
What is it that you dislike about the k501s?
The K501 has a relative low amplitude bass balance. The(stock) K501 has a brittle(a depression in the midrange band) sound that I find annoying.
What is it that you prefer with the mod?
The modification removes the hole in the midrange.(measurements available upon request) This makes the headphone much smoother sounding. In fact, it sounds more natural/balanced on high quality acoustic/jazz/blues/classical than any other headphone that I have heard to date, regardless of price.
I appreciate the offer for the listening impressions, but I won't bother you since I'm sure our ears are different. I'm not sure how helpful it would actually be.
Actually, when using the same music, and listening in the same manner(in controlled settings), trained listeners/audio enthusiasts tend to prefer the same sound most of the time, according to credible perception research.
If you could just keep an ear out for headphones that you find to sound neutral, maybe even dry, and pleasant with most types of music, that'd be great!
Modified AKG K501, if you use it only on high quality recordings. The Ergo A.M.T. might be even more versatile, but not quite as natural sounding on high quality acoustic recordings. However, the Ergo A.M.T. is costly, if you can find one to purchase. AKG K1000 is also interesting, but as I said earlier, I have not had an opportunity to evaluate this headphone thoroughly.
-Chris
