HD-A2~ series firmware 2.7
asjamias
This is a problem with the disk you burned. I have had the same problem with the one I created. Ended up giving up and am waiting for it to work in the automatic download.
so you just updated it through an ethernet connection then? how long did it take?
adk highlander
adk highlander
Sith Lord
No. I have had no luck creating the disk. Went through 5 cd's and have given up.
To my knowledge it is not available for the update utility in the player. Everytime I try it is showing the 2.5 firmware.
asjamias
so I tried another disc, a Verbatim CD-RW...now it says this is not a DVD format blah blah....
looks like only thing to try is ethernet or call Toshiba.
adk highlander
adk highlander
Sith Lord
I'm with you. Been there.:confused: I may call them on Monday as well.
Nomo
Nomo
For what ever reason I finally got the firmware to update via disc.
I used a Verbatim CD-R. This time I downloaded a trial version of Nero and used that rather than Roxio (which had helped me ruin a half dozen discs).
I'm not really sure whether it was Nero or just dumb luck.
mnnc
Well, got my firmware disc from Toshi and still get a "...cant read disc/ dvd blah blah blah..."
Yes you read correctly. Update disc is from Toshiba. I'm going to call and follow up with results whether pos or neg. This is bull. Had I never heard about an update I would be fine due to no quirks with the a2. But, knowing there is an update I want it to be up to date. This stinks.
NicS
NicS
I recieved a bad update disc from Toshiba also. I called and was told their aware of the situation and would send me a new disc.
They were very nice about it. I think there tech support is excellent.
By the way, my A2 was and is working flawlessly with or without updates, thats one reason I'll wait for an update disc from Toshiba.
jeands8
Had no trouble (mirror image settting) copying from the canadian site using nero software. I cannot remember where I read that you must download from Canada if you have a canadian player. Jeands8.
Bryce_H
Bryce_H
I burned the file to a disc np and updated my player.
NicS
NicS
Update:
Received the second upated disc from Toshiba yesterday. Installed, reinitialized and everythings AOK :D
cheapskete OCer
hey guys i have updated twice now via cdr with no problems are you guys using a iso burnign program to put the update on the disc? if not that might be your problem, heres the on i use and its free
http://www.ntfs.com/iso-burning.htm
download the setup exe file also make sure you extract the files from the firmware zipfolder then run the active iso program its real easy
hopefully this helps you guys out
GlocksRock
GlocksRock
I too have updated by cd-r twice, both times using a Memorex CD-RW and burned with Nero. But now it's connected via ethernet, and hopefully will continue to receive updates even though HD-DVD may soon be a thing of the past.
