Harman Kardon AVR 1700 blinking amber light
theproman23
I've had my receiver for about 5 years now and picked up on sale for $199 at Best buy so figured it was pretty decent deal. I'm not the biggest fan of the menu/interface but it's done the job fine up until yesterday.
I recently moved and have been setting up my surround sound setup little by little and have had two tower speakers (Infinity Primus P363 Three-way dual 6-1/2-Inch Floorstanding Speaker) for the fronts and have got them to transmit sound by turning the sound off to the TV but with no Center it didn't sound right so I went back to sound to tv till I managed to get my Center Speaker wire run. I used to a Energy Star center I had from a surround sound system I bought together a long time ago. I finally did that last night and hooked everything and then turned sound to TV off again and started getting my surround sound but as soon as I made the Center speaker active I started noticing the sound fluctuating between the fronts/the center and then finally the receiver just turned off on it's own.
Now when I try to turn on the receiver it lights up the power light to white for about 1 second (no display) and then goes to a blinking amber light. I've tried researching the issue online but can't find anything and I've tried the reset, by holding the surround mode button for 5 seconds, and it looks like it's reset but the same issue persists.
Is the receiver done for? And if so, might I have done something with my setup to cook the receiver? It would seem odd I did the latter as I've had an assortment of speakers together on this system on and off for years and I've had no issues. Now if I did cook it then I guess I can't do much about it and would greatly appreciate some recommendations for a solid receiver that I can replace the Harman Kardon with.
I bet you had a speaker wiring short, that fried an amp and shorted the power transistors.
Yes, the receiver is done for.
Check your wiring very carefully before hooking up a new receiver.
I would look at the Denon/Marantz and Yamaha receivers and avoid the rest. Get one from the middle of the pack and avoid the bottom end. Start at mid price range.
theproman23
Thanks! Not the news I was hoping for but makes sense. And now that you mentioned that I might have shorted the wires I went and looked at my speaker, I usually use banana plugs and I couldn't find them last night so I ended up hooking up the speaker without them. Upon closer inspection I over stripped the connections to the speaker and I think they ended up touching when I turned the speaker to face the front.
Thanks again for the recommendations!
theproman23
Just purchased the Yamaha RX-V579 to replace the one I killed. Any thoughts on the receiver?
Cosmic Char
Cosmic Char
Sorry for your loss...at least you got to buy a new toy!
