Gene,
> Using multiple even # of subs (ie. 2 or 4) correctly positioned also works wonders in creating a wider and more consistent listening area of smooth bass response. <
Understood. But only below 80 Hz or so, depending on room size and of course the sub crossover frequency. So I agree that multiple subs are great if you can afford it. (My one sub cost $2,000 and I'm not about to buy three more!) Then when you add bass traps you really have something to write home about.
> You are incorrect about EQ or more relevantly used minimum phase PEQ’s NOT reducing ringing. Low-frequency room resonances behave as minimum-phase phenomena (Dr. Toole recently authored a paper on this that he submitted to AES). According to Dr. Toole, a parametric equalizer that matches the frequency and Q of a resonance can be used to reduce its amplitude and, thereby, it’s ringing. It is totally predictable <
Yes, I know the theory and this too has been discussed endlessly. Please forgive the link to my site, but you may find
THIS direct comparison of bass traps versus EQ interesting. It's a
huge web page with 2.5 MB of graphs and photos, so I'll give you the conclusion here:
Contrary to the claims of EQ proponents, an expert in the field was not able to reduce ringing even a little, and in fact his attempt to bring up a few nulls caused the ringing to become worse. In fairness, in the follow-up discussion at AVS another expert pointed out that the first expert did a poor job of setting the EQ. I then asked the second expert to show that he can do a better job and reduce ringing by a meaningful amount. That was months ago and I've never heard further.
> it works only for a single listener. <
Bingo. And the "correction" is so localized it doesn't even work for both ears at the same time! If you view the graphs on the above page, look especially at the first two showing the untreated room (no traps, no EQ) at the listening position and also four inches to the right. My ears are seven inches apart. I may have a big head, but not dimensionally!
So for a normal adult the change from one ear to the other will be even greater.
Only four inches away, and even at frequencies as low as 40 Hz, there's a very noticeable change in the response. So there's no way one EQ setting could correct the response for both ears, let alone provide the
incredibly critical balance need to reduce ringing. I do understand that in theory it might be possible to reduce ringing. But only in an ivory tower, not in the real world or for two ears at the same time. Let alone for you and the person next to you on the couch. I have seen Floyd Toole's oscilloscope display showing ringing being reduced. What Floyd doesn't show is what happens when the measuring microphone is moved an inch or three, and he doesn't say how many hours it took him to set the EQ. In fact, such a high precision is needed to counter ringing I bet it would quickly drift out of whack over time and/or with small temperature changes.
--Ethan
