bpape said:
WmAx,
You've done a wonderful job of avoiding my questions and simply restating your opinion or shifting the discussion. My statement was that while qualifying it as your opinion, you go on to present that opinion as fact unless someone can disprove it with scientific studies.
Incorrect. I stated that nothing of credibility of which I am aware shows that they will make the substantial differences claimed. What I did was to offer plausible reasons(
based on specific circumstances of what will for certain affect imaging consistancy) as to why they may be erroneously concluded to offer said performance. I do no such thing as offer my opinion as fact. Go back and read my 1st reply in the thread and the posts in the linking thread that are addressed to you.
1. Have YOU heard a Lowther/Fostex in an actively bi/tri-amped system? I have. I wasn't a big theoretical fan of the them either - until I heard them.
I do not offer my personal impressions or what I 'hear' in a factual debate. It does not matter if I am deaf. But I am curious : How was this Lowther that you refer to used as a full range, if it is in tri-amped configuration?
Again, the small cabinet helping to make the speakers disappear not being significant is simply a restatement of your opinion. I'll restate mine and say that I disagree - as do many, many, many others. We'll just agree to disagree and move on.
If a small cabinet width as found on very small bookshelf monitors has a substantial improvement effect on imaging in itself, then by this logic,
only speakers with such a small cabinet baffle must have excellent rated imaging. No speakers with average or large size baffles can have excellent rated imaging based on this simplisitc assumption. There are several variables relevant to the situation, and so far as I can tell, they are being ignored by the vast majority of people, and a conclusion is being prematurely concluded.
3. Rip stated clearly that part of what phase issues in xovers can cause is frequency related and ARE audible. While the phase itself may not be audible, other side effects are - or can cause additional xover complexity to compensate.
Rip Van Woofer gave a limited amount of information. And what was not further stated, but what needs to be stated now, is that a multiple source system trying to adhere to the best on axis phase response(1st order) is going to cause far more problems in frequency response off axis as compared to a steeper slope rate. His blurb about frequency response difference was a qualifier. The higher order system, using the same drivers and layout, will have superior frequency response linearity off axis, and equal response on axis, as compared to the 1st order system. Additionally, a properly engineered 1st order system will result in increased cost, because the drivers will have to operate in a significantly wider bandwidth, and thus be required to have greater power handling as compared to a higher order system. The cost of getting better on axis phase response(which has little to no audible effect on it's own) is to eschew off axis response(which is a critical parameter for audibility) and to require drivers with a wider usable bandwidth and higher power handling. No cost is saved. No complexity is saved(because it requires as complex or a more complex crossover to tame drivers to operate optimally in this wide bandidth). Important parameters are ignored to focus on a parmater that has not been demonstrated to have a signifncant effect on audibility.
Please state the 'credible perceptual research' and the areas specifically the parameters where it is very poor.
I assumed that you already knew which parameters I was referring to; that's why I did not specify them earlier. Here are the critical areas as demonstrated in [1][2][3]credited perceptual research, where a Lowther or Fostex or other popular full rand driver falls flat on it's face:
-polar response(due to the effective radiation area, upper midrange and treble bands beam severely, causing a very different, and poor response off axis)
-frequency response(response is not smooth)
-resonances(frequency response is not linear, maninfesting many severe resonances especially into upper midrange and into treble)
-frequency response bandwidth(
the low frequency respnse is not actually full range with these small drivers, they can not respond to the lowest frequencies effectively. Another driver must handle bass if true full range is desired.)
-non-linear distortion(
the speakers can not remain linear at the excursion/incursion required for true full range use at lower frequency SPL at moderate to high SPLs, thus resulting in high levels of THD)
Additionally, a parameter I am not aware of a specific perceptual paper, but is a very obvious parameter which must be addressed:
-phase modulated distortion(a.ka. Doppler Distortion)(
the speakers can not really be used as full range, they must have another driver function as the bass driver, otherwise at moderate to high SPL, Doppler Distortion will manifest in the upper midrange and treble bands due to excessive cone movement while reproducing frequencies with very short wavelenghts)
-Chris
[1]Loudspeaker Measurements and Their Relationship to Listener Preferences: Part 2
Floyd E. Toole
JAES, May, 1986, Vol. 34, pages 227-235
[2]"The Modification of Timbre by Resonances: Perception and Measurement", Floyd Toole, Sean Olive, JAES, Vol. 36, No. 3, 1988, March, pages 122-141
[3]Just Detectable Distortion Levels
James Moire, F.I.E.E.
Wireless World, Feb. 1981, Pages 32-34 and 38
