I have 4 of these monoblock amps. 3 Blue and 1 Green.
Up For Sale: Two pair of Odyssey Audio Stratos Extreme SE Mono blocks. What can I say that has not already been said about how they sound? They are absolutely wonderful amplifiers. Reason for selling? Just scaling back and simplifying and downsizing. I recently moved from Utah in a big house to a rental south of DC. Priorities have changed.
My asking price is $1749.00 per pair with two pair available. Buyer pays actual shipping, and these will be about 70 lbs. a piece. My preference is USPS postal money order, but will accept a personal or business check, and ship when cleared. If PP is preferred, buyer is responsible for all fees.
Now for the good stuff, what these puppies are packin’ inside. The specs here are for the Mono Extreme from the website. Klaus told me they are the same, just a little extra magic added.
The Good Stuff:
• 1 x 200+ Watts RMS @ 8 Ohms (each)
• High Class A /AB
• 2 Ohm load stable
• 1 - 600,000 Hz frequency range
• 120,000µF memory (each)
• Additional 60,000µF memory bank for 180,000µF total (each)
• >120 amps current delivery
<0.04% THD (not audible)
• >800 continuous damping factor
• Input impedance 22K ohms
• DC offset <1 mV
• RCA & XLR (bridged) inputs
• 400 VA Plitron transformer (each)
• Additional 400 VA Plitron transformer for 800VA total (each)
• Sanken Epitaxial Planar Transistors 2SA1216 & 2SC2922
• Anti vibration dual thickness PCB
• Power consumption when idle ±30Watts
• 4 internal fuses 250V/6.3A, 5x20mm, fast blow
• Additional electrical protection fuse
• Higher performance parts: Nichicon Muse capacitors, Vishay/Dale resistors, extra WIMA metal film capacitors
• Power consumption when idle ±35Watts
• >66 lbs / 30 kg weight
• Dimensions: 19 width x 18 deep x 7 height (in) /
48.3 width x 45.7 deep x 17.8 height (cm)
