Well....Comparing raw data from one reviewer in AV Talk to another reviewer with different equipment and methods (ie. you) is not a good practice in the audio industry. You know that. I don't listen to numbers, I listen to speakers/subs.
The 3" port creates audible chuffing. This is a fact. This means that the DD18 will sound much better at 20Hz or any other frequency. Use your ears and it will be very obvious. If you didn't hear it, then you are indeed just listening to the numbers.
If you were totally impartial, you would have mentioned that in your first statement. So on the whole, the DD18 out performs the PB10. You know there is very little information available at 20hz.
All of your comments regarding SVS are constant fawning. While they are good subwoofers, they are not without their flaws. Try a balanced approach, and you will be in less controversy.
